Let's get this thing running better.
KBMKVIII
Texas
can you share more info about the resistor for the map sensor?
ohms and placement?
ohms and placement?
i have the same on my dually.. been on there so long i forgot what size it even is.. placement is simple. one end to one map wire and the other end to a different map wire.. i put mine on a toggle switch for some odd reason...
old man dave
Petaluma, CA
Its probably not a resistor but a 4.7 volt zener diode to limit the 5 volt max output of the SD MAP sensor to 4.7 volts so the PCM doesn't think its seeing overboost.
ja_cain
The resistor would alter the pressure vs. Voltage curve where as the zener shouldn't effect the curve up to the 4.7 volts that it's clamping at.
