Jmoore1225
- Joined
- Dec 30, 2011
- Messages
- 334
- Reaction score
- 0
Had this happen today.... Truck fell on its face from a hard roll into out of a turn :-/
I didn't know you could bump the factory regulator. Would that help running the higher tunes?
I'm no expert, just trying to help by sharing what I read from someone who knows more than me. I am pretty sure he explained how he raised the pressure in that thread.
Check low pressure fuel first should maintain around 3 psi all the time at the cooler
Put a digital fuel pressure guage on it and drive it around. My lpfp was going out and it would start out 4.1psi, 4.5psi, then on accel it would drop to 0.7psi. Sometmes it would quit, but it always stored codes.
Replaced lpfp, problem solved.
Im not sure more low pressute fuel is tge answer anyway. Checking to make sure there is positive pressure at the time of shutdown is what is important. Ford pumps dont really seam to care how much pressure they have as long as they are not in a vacuum.
That being said my last trip ti the track I was having issues with my truck acting like it was out of fuel but it was in the tuning because I loaded an old gearhead tune and it fueled fine... unsure why at this point
Sent from my DROID BIONIC using Tapatalk 2
For what it's worth, Today I dynoed on my stock lift pump, swapped over to the air dog DF 165, and re-dynoed. The switch took all of 10 minutes as all the lines and wires were run, I just had to un clip, and re-connect 4 fuel line fittings, install a fuse, and pull the power supply to the stock pump.
Back to back dyno runs provided 0 gain in power or rail pressure, but I was able to maintain a minimum supply of 7 psi as opposed to 0, if not a small vacuum. I'm sure the lack of pressure contributed to the inability of my injection pump to maintain pressure, but the damage is done. Now the next group of mods on the list include 60 hp nozzles, and a pump that will maintain them. No looking back now. I'm tired of fuel pressure limiting me.
riest:Moral of the story: Don't let your weak lift pump kill off your injection pump. FWIW, my injection pump has only about 80K miles, but has probably had a weak lift pump it's entire life. 177K total on the truck now.
I want to see this but now with the fuel bowl deleted...... I want to see if there is any real restriction with it and if it will cause lower rail pressure, and if there is any gain. See if all of the hype about the elite airdog mod is what its cracked up to be....
