The airdog upgrade is mostly for guys running larger injectors, and guys who need the space where the fuel bowl sits. Only a small gain will be had on trucks with stock injectors. When you have enough fuel demand to suck down the pressure at the factory shrader valve below 4 psi then it's a definite need since there's more flow and regulator control with the upgrade. The extra filter is also redundant, and unnecessary so it's a plus to get rid of it for that purpose.
Thanks. That clears up everything. I believe I read on yalls website that with the upgrade you can run up to the 110 (I believe) injectors. Will there be any benefit in running the airdog with the upgrade and 60 injectors with everything else stock........ Maybe a batmo.
