Mechanically Injected 7.3 Trucks Info/Pictures
Shelbyville TN
Has anyone seen Unlimited’s new dyno numbers today.. Absolutely impressive 2180 hp and 2821 for torque.. Really happy for this hardworking shop. They did it on a single top which incredible as well.
Shelbyville TN
Turbo I do not know.. They posted it on Facehooker and man the Cummins guys are knee deep making claims with no dyno sheets. I for one am impressed as I believe it will be able to pull in the prostock class pretty decent.
NyCowboy87
Arkport, N.Y.
They had the dyno sheet on their video of it. Also bent a rod unfortunately. I do believe it is a 3.6 smooth bore but that is just pure speculation, could be larger. Bunch of recent pics with the truck having cut tires on it makes me think that if they are doing any sanctioned events that leaves them with either 3.6 or super stock.
hucorey
Defiance, Ohio
Here's the truck I sponsor with our conversion kit. It was at UCC this past weekend for those that made it.
It's turned down quite a bit as it only has our plate girdle kit instead of our bed plate.
Sent from my Pixel XL using Tapatalk
hucorey
Defiance, Ohio
That is awesome Corey!!
Next weekend is the plan to do the first full heat cycle on this one, and then hit the dyno to dial it in. We didnt build the bottom end to handle 2000hp as its just a plate girdle, so we need to dial it down to around 1200hp or less for this season.
gwunter
Logansport, IN
That engine looks amazing. Well done. But I have a question(s). Those injector lines look incredibly long, assuming they are long for intake tube clearance? I notice the pump gear has a smaller gear on it, what will this drive? I also see you didn't create new valve covers like hypermax, but instead you have a spacer between head and valve cover. After the injector line passes through the spacer is there another short injector line leading to the injector? Again, great work. You ever pull in North Central indiana?
Sent from my SAMSUNG-SM-G900A using Tapatalk
