Most power and fastest times with a VGT......
Josh@DirtyDiesels
PA
About 115k miles, they were my stock ones that we sent off to ii to get modified into 225's. gonna buy a new ford set and swap spool valves and see what that does. Then send the new sticks sent off to get modded into ???
When are you going BIG with this thing and getting into the 10's!?
stonepusher
San Antonio
Gonna hit the track Wednesday and see what it will do, gonna fire off one stage and see what it does, it did 11.5@116 at worlds on one stage. Gonna see if I can cut that down a lil bit
stonepusher
San Antonio
Made the 10's!!! 10.93@123 with a 1.61 60ft. Started the night off run fuel only and couldn't get good 60ft's truck was a consistent 12.0@110 on fuel with 1.69 60ft's. There was a diesel vs mustang event going on that we didn't know of and I was called out by the track manager to race the fastest mustang. So we raced and on a stage and 1/4(didn't hit the 2nd stage until damn near 1000ft or later as the mustang was starting to creep) I went 11.3@119. So next run I went full both stages and did 11.11@122 with 1.66 60ft. Heated the bottle up to get good pressure and went fired off both stages again to get 10.93@123 1.61 60ft...... Couldn't be any more happy! Huge thanks to Truck Source Diesel with out them truck wouldn't be where it's at today and wanna thank Will(william_ace) and James Barder for letting me experiment with their turbo! Barders 68mm powermax is a awesome turbo, not only did it handle the nitrous but has blown my mind away with its mannerisms on the street!
stonepusher
San Antonio
ford rules
Awesome!!!
Forgive me if you've said already but what are the specs on the truck, Inj etc?
Dirty_Stroke
Tuscaloosa, Al
Does that say 6.87 in the 1/8th!? Congrats man that thing is running awesome. Do you contribute the good times to the 4R100 or the 68mm?
Chris
San Antonio, TX
Mikes truck has always ran solid. I dont beleive any one piece is responsible for it running a 10, The truck gained 30-40 horse across the board (fuel only and with the same nitrous jets) going from the VGT SS to the Barder 68. Then snuck a few more tenths out of it by swapping one of the jets to a larger one. The 4r definately helps too as it puts down every hp the engine makes and does so efficiently. If you watch the video you can hear how quick it gets the 1-2 shift and lockup all at the same time. Its just a good example of a truck with a good combination that hooks up well and has had plenty of live tuning to get dialed in to the sweet spot.
Extended Power
Excellent runs and times.
? For you...are you going to put a cage in it now?
Did the track kick you off until you put a cage in it?
