MPD Towing t4 setup install
Pizza pig
MD
I want someone to drive my truck to see in itself how easy it is to dive. My brother drove it and loved it, hasnt driven it since the new setup and had no problem keeping it clean on the street and building boost just fine, and we live in the appalachians. He has the same charger in his dmax and that charger lights like a VGT, the 6.0 just doesnt have the bore and stroke to making a big charger spool well.
MorganY
college station, tx
The setup is OK for awhile for the 6.0, and then many get tired with it and are looking for something else. Do it once, do it right, and do compounds. A big single, even with the magic T4 up pipes, you'll cruise around 900° while climbing up to 1000° going up a hill unloaded, even in a Borg Warner. Think I'm blowing smoke up your a$$? Ask anyone here with a 66 and see what they cruise at for Egts with 190's-205's.
Pizza pig
MD
Flat ground i cruise at 800-850 in 90* humid heat, now in this cool weather i cruise flats at 750 all day. I can get up to 1200 at 68mph with cruise set locked in overdrive going up a 7-10% grade here in CT. No issues driving it, i can keep egts in check using my brain... I want compounds fo mo powa! Morgan wish you had the chance to try one of these bw t4 setups over that garrett turd lol
This setup isnt for everyone, especially those with lifts and large tires and stock gearing
06f250powerstroke
ontario, canada
i tryed a bunch of stuff turbo wise, as far as best overall turbo set up. 64/68/83 T4 is my favorite for a do all set up. yes you can tow with it as long as you have a brain in your head. dont get me wrong i like my new 66/74/91 its just not as responcive as the 64 was
OneStockQuik6.0
I have 285/150 mpd injectors and 66/74/91 turbo along with their manifolds and using my factory oil system,Truck spools great and has been an 8.0 at 86 in the 1/8. I also have towed with this setup and it tows great, spool up is so much better than my old II 64/70..I use the same file at track and while towing...
Craig@MFI
Will you send yours out to be tested from a 3rd party as well? Just curious.
Garrett
probably getting paid at work to post this from my bionic
No I wouldn't send mine to anyone to test them I don't need to prove a point..I don't need to sell anyone injectors.. What we have works is proving to work and last..and everyone that runs my injectors will tell you the same
Extended Power
Craig, can you pm me with what it would cost to have these injectors gone through, and repaired if needed, please.
Breaking Habits
Mapleton, Illinois
Don't sugarcoat it.
What Craig meant to say is..
I do it correctly, and it works, and I don't have to justify myself and show my work to anyone else who hasn't figured it out just to meet their level of satisfaction
Who gives a **** what anyone else thinks, if they flow, work, and have minimal fuel dilution, you've obviously figured it out and don't have to justify it to anyone except your SATISFIED customers
Redneck6.0L
That's so cute. MPD and RCD are now officially bum buddys LOL
But yes the MPD 285/150 do work, Erics run high 10s on nitrous in the 1/4 @124. I think Eric said icp dropped to 36-3800. Not that much of a biggy.
This has been a long on going issue with 6L injectors. There has never been a set standard to rate them. Hypermax, mpd rate them on a proper flow bench, others rate them at what they can hold internally.
Powerstroked162
On Da Juice
Wa. State
....and the rest don't flow them at all and sell them labeled as the same quality product, for half the price.
Breaking Habits
Mapleton, Illinois
Bum buddies? Not really, we just do what we advertise
So hypermax flows their injectors? That's sad, because the injectors we've flowed with the worst fuel dilution have all been.. Well never mind
