MPD Towing t4 setup install
Craig@MFI
Update
Got a set of our 285/150s in and this thing tows like a dream very low on smoke...barely any street driving it and turbo lights a lot better than stock injectors
Went 13.6 tonight full weight cclb dually with 67gallon Titan tank gooseneck hitch and plow mount
Towed my 46ft trailer with King Kong in it about 4 times now long trips and the white trailer has a slight has on the side...
Truck still needs to be tunes for the injectors it's running same tune for stock sticks
strokin6L
Springville NY
I have a 64/71/70....how much would it be for a T4 housing for it? I'm assuming the turbine wheel should also be switched from the 71?
Extended Power
You may wanna send a picture of the center section to a turbo builder, and verify you have a 300 series...just sayin...
mgeistman
Think you have me convinced on that t4 housing, what's the cost for that housing
Glad to see people getting away from the tight turbine housings............ Bout time. Bigger turbine housing=more flow=better spool to an extent.
Craig@MFI
Coming from the guy would made 4xx on compounds at Rudy's lastyear..
Craig@MFI
No not hybrids regular injectors same injectors we have in budget brawler and same injector we had with whitey before we switched to rcd hybrid
Pizza pig
MD
what youre saying is your 285/150 will hold icp on a 2.2ms tune on stock 05+ pump?
