MY BIG 6.7 BUILD
Athens, IL
That's 1300pw with 100% sticks... That'd be like me running 2400+pw on stockers
1300 Ipw with 100% made 750 on my old truck and plenty of fuel to spray it to 1000. Did it a lot at 1300 Ipw.
I know I can't wait to run a 2500+ with the sticks I have.
No way in hell you can use that much fuel. If you even had enough air/nitrous to burn it you'd be well over 2000hp....
I'll have to take a look at my nitrous tune.. 2500us is a lot with 100% sticks
Made 1365hp at 1500 Ipw with 100% injectors. and two wide open 0.120 solenoids.
bigrpowr
<How I Fly
Administrator
so the op should make about 2000hp at 2500us . awesome.
4EverBoosted1
First clap down.
Told you they were junk... Lol
Swsignal5
2000hp in a dd... that would be cool to see... if possible...
This thing is honestly so street able. I can't believe how good it runs. Doesn't lope and shake when I stop. I can ease into the throttle and get to speed with no smoke. I'm very impressed. This setup for a dd turned out better than expected
that in itself is insane!
Swsignal5
Lol trust me my mind is blown. The engine doesn't even move with the torque. It stays exactly where it's at and doesn't twist. Cruising bp is 2:1 and under load it's 1:1 right now. 50 mph I'm seeing 3psi boost to 4 psi bp. At 1200 rpm
