Six_Sloww
Is that your first hard part failure?
Only failure trans Other than clutches and steels
That's the problem with such a strong stock trans, it takes so long for the aftermarket to come up with better parts if no one is really breaking them.
Does it have anything to do with tuning? Seems kind of fast to let go, how much hp are you pushing?
Did you ever get your suspension issues fixed?
Third trans rebuild in less than 2 months.![]()
I've had one other guy do that. He makes around 950hp at the wheels. Imo it's more from too little slip time in the tune or spinning then catching traction.
Lots of other making that power and not having issues yet. We are in process of a new shaft... Gonna take a little while before available.
you running the E-Hub from suncoast, or standard ford ?
that shaft seems to be the one too wana break not really surprised
well suncoast doesn't do anything with he shaft just the clutch on the back side i have seen both break
