smokinstroker
Your bov should be a sealed system unlit you lift the throttle.
With pressure ontop of the spring it is a closed system until the solenoid is told otherwise.
.125 jet!!!! come on!!!! LMAO
I'm curious to see how it spools, seams like no one runs that large of a housing on a single.
It will most likely run worse we have always lost power with 1.10 housing and you Probly won't keep it lite threw the gears
Sent from my SAMSUNG-SM-N900A using Tapatalk
