Bushwood_6.0
Ok same as the terra grapplers. 28 at the track
I run mine a little lower than that. I always run 5psi lower in the rear at the track. I don't have traction bars though.
We can hook my CTS up to it at Rudy's if you want since I won't have my truck. I'll bring my laptop too so we can look at the datalogs. Let me knowI don't have a cts, my livewire doesn't read voltage. I'm going to borrow the snap on scan tool and make a street pull
I had the same issue with my truck and the SCT livewire... So I used my analog cable to tie into the actual ICP sensor signal wire and then just read the volts... Now i can monitor ICPv
