The T1000 hasn't been released so there hasn't been any failures yet, been watching the progress and it's goin good. Yes I can data log. Joey stands behined his product too 100%, before we get off topic on ranting......T1000 is still in beta testing, if it decides to fail on someone that's where you fix the fault and produce a better product.....Joey laughs at the SRP1 compared to the T1000......just sayin.
I'm still curious where/when/why/how this laughing came about in regards to Joeys attitude towards the Srp. Duty cycles UNDER 40% when the Srp is pushing 300/200's isn't much to.laugh about. The t1000, tuning aside is working HARDER to do less work. I've already stated why this matters for me. Also I'm not running a 250 but a 275 and 200% nozzle. My situation will be demanding MORE oil not less.
In his defense that could be in the tune, but still...
We've already gone over the tuning here
Right. It's the same thing that other people using that exact same pump say. I'm green when it comes to hybrids and oil issues. I'm honestly surprised my 175/100's were able to run with a strong 17° stock pump. Better than 3/4 throttle on a hill or loaded and icp would tank. It would get down to about 2400 and I'd back out of it.
Here again, more tuning talk and discussing icp dropping.
I'm appreciative of everyone's help but I'm just not comfortable with the t500 for 275/200s. I'm not even sure(I don't know) if an adrenaline would cut it. Andy said his is.good to go with 238/100s. I'm not sure how much more demanding a 275 is especially with twice the nozzle.
Here again, I'm going for a 275/200. Just as a stock pump can push 238/80s but a 250/100 will be too much the difference from a 250/100 to a 275/200 is quite dramatic. Not only that but I'm comparing the 40% dc of the t1000, which isn't available, to the srp1.1s. If the dc is that high on the 1k, the 500 is really going to be grunting. That's what we have here, pumps I can actually buy.
Yea I am beta testing. 40% isn't high at all, this is in my 140 tune. Joey isnot concerned one bit about the DC.. Hell, he would love for me to push it more but I'm happy where it is at
Sent from my PG86100 using Tapatalk 2
Right, but ITS NOT FOR SALE. So my option from terminator is the 500 which isn't.gonna do it.
40% DC in a tune that dynos shy of 550 and backs it up with track times and MPH is juust peachy. The T1 is a slick pump you got there Ken.
Holds what 3500ICP at just about 40% ? Not bad in my opinion.
Joe, yes a stock pump can suffice on 200% nozzles (provided the pump is in tip top shape) But an upgraded pump (SRP1 or T1) will be better and produce more power.
Duals will be even better. But I will agree with your statement on most dont need that amount of volume... This isnt 08, and we aint feeding B-codes.
Tycorr 20% DC in a tune that produce over 500hp, On a single pump. I'd safe to say not gonna happen. BTW tuning does play a roll in DC....
Roger that. I understand. If the t500 is at the same duty cycle running 250/100s how will this translate to a 275/200? Why not have a lower dc if it's possible with a single pump? My initial post was asking what is best that's out. Too many reasons there are not do duals. So it comes down to the t500(the 1k isn't technically in existence), the adrenaline, or the srp1. I was told by someone who.sells the t500 it is NOT enough oil for a 275. 250/100 is a decent cutoff. One of Joeys testers even said it's meant for smaller hybrids in this thread. C004cobra even posted some setups he's ran and said the t500 drops icp with a small-medium hybrid.
Moderator Andy is running 238/100s with an adrenaline. Lowdown is running his 250/200s with an adrenaline. I'm not sure if they are sufficient to run a 275/200 though? I don't want to be the tester either.
It seems for singles, that are available and in production the Srp 1.1 is most capable. Nate pushes big injectors with them at lower dc%. I'd rather have rock solid icp than low rpm problems.
It seems that my options are two. Dual termies, dual.stealth pumps, or a single stealth replacement pump. And obviously the gen 3.
I'm trying to clarify for others, like myself, who don't know. I'm interested in what's the best approach. Duals aren't needed in this case.
I don't want an oil war thread either. It shouldn't have to.go there. Some pumps do certain things.better than others.
