Needing info on Dual HPOP's
stonepusher
San Antonio
It's time to move a few steps forward with my build. I am looking for some info on dual hpop kits. The truck is gonna see the street some but more of a track toy. Whose has experience with them and which kit? Pics would be awesome too, thanks in advance guys. I
stroker57
frostburg,MD
I'm running warren diesel kit really like the kit nice clean look. Keeps up with any size injectors you'd like to run.
strokin6L
Springville NY
how long you been running it? any problems with it so far? What size injectors you running? Did you hafta fab up a new hot side CAC pipe...or is a new pipe part of the kit? How is the return from the pump set up....is it returning back to the pan or somewhere else? Sorry for all the questions...just really interested is all.
stroker57
frostburg,MD
About a amount now and no.problems so.far as far as injector size I'm running 430/150s.yes you need a new cac pipe but it dose come. With the kit the pump runs In to the factory pump and returns that way I can get pics tomorrow for you guys. With 430/150s it berries my 4000psi hpop gauge
strokin6L
Springville NY
Awesome.... thanks for the info man. Yeah some pics would be cool. How long did it take to install? Wow 430/150's....what size charger you running? Smoke much? lol
patrick@WDI
If that's Dustin its not too bad until you mash the pedal but his truck pulls like a freight train... definitely gives you permagrin
He has an s475
e.nickkk
I'm running one also seems to hold icp just fine no issues so far my hot side pipe didnt fit so had to customize it a lil but still happy @wot
TooMuch03
West Bend, WI
I am running a dual HPOP setup that I built. I am using a modified version of Jesse's bracket for the pump with my own pump, pulley, and feed lines. My system feeds to the rails, rather than just to the test port on the pump. It works fine so far. I also draw the oil from the LPO system rather than from the pan. Jesse's kit is very nice, I just wanted to do things a little differently. Jesse was a huge help to me while I was designing the system.
strokin6L
Springville NY
Adam...are you feeding the front of the rails with having to drill a hole through the front side of the valve cover to put the line through? How are getting oil from the LPO system? Got any pics of how yours is done?
TooMuch03
West Bend, WI
Yes, I ran the line through the front of the oil covers into the rails. If I had a later truck with wavy rails, I would use the ICP ports on the rails. That would be easier than drilling out and tapping the AWA fittings at the ends of the rails and trying to seal the valve covers, like I did. Since I was told it couldn't be done, I just had to do it lol. Mine pulls oil from the return line from my BPD oil cooler. I have an earlier style cooler so the block that replaces the factory oil cooler cover does not have built in pressure relief bypass that the new ones have. If my truck had a stock oil cooler, I would pull the oil from the test port fitting in the front under the intake manifold.
09stroker
Texas
Are you measuring oil pressure?
TooMuch03
West Bend, WI
Yes, there are rubber grommets. They actually press tight against the ends of the rails when the valve covers are on.
