NEW 6.4/6.0 Manifolds just in!!
Dzchey21
wyoming
I.was under the impression electric HP is different than combustion HP
Meaning 5hp.electric is more than 5hp gas engine
Let me do some looking
redx
Edmonton, Alberta
Well this is getting way off topic, hp is hp.
Electric motors generate maximum torque @0 RPM, giving a ton of power out of the hole. A piston engine is way less efficient than an electric drive setup(33% to a 50-90% on electric setup)
Dzchey21
wyoming
Correct your right on the effiency but they are rated different
Electric motor is rated at constant HP and gas is rated at peak HP. Also the electric motor.produces power during the whole revolution while depending on.how many cylinders Ect there wont be full HP at any giving crank angle.
Which is why they will.produce torque at 0 rpm.
Anyway its way off topic I now want to.dyno a 10 HP electric motor lol
steedspeed
How long does it take to produce a set?
Too long right now but I'm just getting started.
I can make 4 cummins every day right now and expect to do the same with the Fords. i'm also building on to the shop this year so I can add some more machines.
Also I'm working on programs that will make a complete set of Fords over night so I'll have at least one set made every night while I sleep.
this will be the best thing you ever do to your Ford. You have no idea how good they are.
