Take the fuel cap off. Take the inlet line to the pump off. Fuel should flow if there is anything in the tank. If there is fuel in the tank, and no flow, Put a air nozzle off your air compressor in the line and pull the trigger. If it flows now, hook everything back up, cycle the key a couple of times for 30 seconds and start it up. If it runs OK, drop the tank and do the Hutch and Harpoon mods to it.
BTW, with the fuel filter lid off, you will not get fuel flow if you turn the key on. Unless, of course, somebody has gutted the standpipe in the fuel bowl.
