Not recommended. Is my opinion
Nope. Let it ride. If you replace it, it WILL leak.
Since I have the engine out and the oil pan off
Should I replace the rear main seal?
Just because I’m in there? Don’t see any leaking but it is 26 years old
Thanks
I think I read somewhere that the 7.3 rarely leaks at the rear seal.
You gotta do it just right. I put the wear sleeve.
You could rhino cover the new oil pan
Depending on the paint, may need to take it off to bare metal
Make sure the oil dipstick to pan adapter is done right or get another different/better adapter.
