P2263 and P2563
CamTom12
Huntsville, AL
Replaced the tube and sensor today. Probably took me about 10 minutes of actual work. I took my time, helped some other guys out, and let the rest of the truck thaw out though.
There was a bunch of carbon sludge in the old tube and sensor. I'm going to clean them both out real good and keep them in the toolbox for backups.
forcefed6.4ford
Medicine Hat... Again
I had the code once. Cleared it and it stayed away. Changed out the sensor and tube. Not getting the code but my VGTDC has me a little perplexed. My VGTDC is all good driving around town, and as soon as I get up to highway speeds it goes to 7.001%. Give the beans and it jumps. As soon as Im off the throttle and holding a steady speed, back to 7.001%. Boost and BP are close to 1:1 running IDP Street.
Any insight on this?
CamTom12
Huntsville, AL
Honestly? Not a clue. I think mine's near 50% or so during highway cruising. I'll check today and let you know - well in 3 more hours, just plugged he truck in!
I'd try to reflash, just to make sure it's not a random 1's and 0's issue.
forcefed6.4ford
EBP vs Boost is back to 2:1 and VGTDC is constantly 70% plus at 70mph. I sent Eric an email this morning to sort this out. This is with a new EB tube, sensor and freshly loaded tune.
CamTom12
Huntsville, AL
Closest I could get you was 50mph.
VGTDC 47%, MGP 5.6psi, EGT 600*F, FAT -22*F, 2WD w/ front hubs locked, new EBP and tube on KEM 345.
The expressway wasn't very express this morning, hope this helps!
mxpowerstroke457
Got this code tonight in 25*F, deleted it and drove around for a little bit then it came back. Haven't had a chance to get the sensor yet, hoping my vgt vanes arent trashed.
Daniel@RudysDiesel
Burlington NC
Diesel tech at local dealership. He said that sensor also controlled how much fuel went to the head and when mine failed it kept dumping fuel in my #7 cylinder. Also after the new motor was put in it the code popped up again and i had a new one put in with an update on pcm...what would cause that sensor to go out?(EBP sensor)
BFT
southern cali
Mainly heat because of the location. The EGRTA and the EBP sensors are the likely ones to crap out on yah.
Dzchey21
wyoming
There is no reason for them to cause one cylinder to fuel more than the other. The injector was the real problem. You got other stuff going on if they keep throwing sensors at it
Dzchey21
wyoming
The reason you keep getting the codes is because there is something wrong with the vgt
Daniel@RudysDiesel
Burlington NC
Replaced the tube and the sensor and when i dropped it off this morning he said he is going to look at the vgt, when the new motor was put in i had all new injectors put in also.
