So i cleaned up the cylinders and found this...View attachment 116170
What do i do? i see you can get sleeves. im guessing you need special tooling to replace a sleeve.
Yes the motor was running ok. But im not doing this just to put it back together with a score cylinder. I have to find a shop that can do it... i don't think the the shop i brought the heads to can bore the block. Ill have to find out tomorrow.In order to use a sleeve will need to have a machine shop to machine the bore and install the sleeve.
Was the engine starting and running fine?
Yeah. im bringing the block tomorrow. If that's what he recommends ill be glad to go that way... save the money on pistons.Hone it, ring it, and enjoy it for the next 300k
Now that he is decking the heads and im using comp cam springs do i have to get the spring pressure checked or use shims?
