Pmax compounds?
EShore,MD
Stage 3 mtw can be had for a decent price and is a perfect match for 190/100s great for everything the op listed and you dont have to change anything but tuning!!! Hell my old truck made great power with it!
kdogg85
As for drop in, then yes the stg 4 will be ok. As for been there done that, sent a postcard, the 66 or compounds will definitely work. Compounds are expensive, but you get to do what you want without much worrying about smoke, lag, high egt's down low.
The 66 would work, but the turbine housing will be the big thing to get right. Greg and Matt are the authorities there.
MorganY
college station, tx
$3500 for a new to the market turbo that MAY grenade in 20k miles.....(I haven't seen a big VGT last over that yet).
If someone has more than 20k miles on a MTW stage 3+ speak up. We would like to know! (not being sarcastic either)
Yes, you get the best of both worlds. But unless that thing has a warranty since its still fresh on the market, I'd rather spend that $3500 on a set of rods.
smokedout250
harrisburg oregon
Well that was a fun read! So lets start over!
My goal for the truck...
The goal is to make a reliable dd, that can tow and be fun at the track every now and then... Injectors will 190-205 100% nozzles... So choices are single non Vgt, twins, procharger or mtw stage 3-4.... Hp is just kinda of a whatever.... I'm looking for a fun street truck..,
strokin6L
Springville NY
Damn strong statement if you ask me.
Lol.... not really. I'd love to see your truck put up against superblazin's(james) to see which one DD drives better and towes better....with both trucks runnin 205/100. I bet james' truck runs circles around yours Greg.
Josh@DirtyDiesels
PA
Do the single 66 non vgt, you can always turn it into a compound setup down the road and it should do everything you want it to as a single.
windrunner408
I believe kingranchstroker can back this up but we've been tracking his Stage 3 and it has (I believe) over 30k miles on it now. There is absolutely no reason that a MTW Stage 3+ turbo should grenade within 20k miles just because it is labeled a "BIG VGT". It has a properly matched turbine wheel and compressor wheel (unlike other big vgt designs).
