post your setup and dyno #s or track times
Kbryant777
Plainfield,IN
Just checking cause everyone's 60' times look ****ty compared to mine. I ran 1.80 or 1.90 can't remember exactly but 14.6@ 91
EShore,MD
Dyno'd 623hp/ 1260 tq on RCD 190/100s, Xtreme X, MTW Stage 3, Built trans, IDP Mild 48v ficm. Ran 12.5 @ 106.9 1.8 (0-60) race weight 8000 lb, 90* outside. Hp calculator puts er at 650 or so. Big thanks to Eric@IDP and Adrian@ MTWs
Mike B
carmel ny
We have almost Iidentical setups Mpd 190/100's Mpd single 66/71/91 with manifolds and uppipes my air dog was acting up. It made 544/1150 on 30 lbs of fuel pressure and it was only at 50 at idle heading to the track Saturday will post some times.
stonepusher
San Antonio
New Fuel only numbers 12.7@105 1.78 60ft 225/100s, VGT-ss, stock trans, stock fuel pump. First time out at the track with new turbo and cal tracs, definitely have some tuning to do with tire pressure and caltracs. Thanks the TSD.
mgeistman
8850# 12.98@ 103mph Fuel only
Mustang dyno 668
Mustang dyno 905 on meth and open -4AN line no2. No track time to confirm Bc of tranny issues.
jdc753
Norton, MA
Stayed out of this thread with my stock truck but...
Best quarter is 14.698
Best trap is 90.79 (before blue spring it would be 89s very consistently)
Best 60' is 1.927 with most in the 1.9xx range
Launched in 2wd inevitable by accident (thought I was in 4wd) had a blistering 3.630 60' LOL and trapped 87 once I finally got it to stop spinning.
Latest dyno was 401.64hp and 792.90tq on a dynojet
Mods are IDP Xtreme race tune for non studded trucks PHP 100 FICM tune blue spring, 5" magnaflow system, and studs. Crew cab long bed 4" lift 35s big loaded toolbox and 250lbs stereo gear and no weight reduction, guessing 8000lbs on the scale.
We have almost Iidentical setups Mpd 190/100's Mpd single 66/71/91 with manifolds and uppipes and my airdog was acting up. It made 544/1150 on 30 lbs of fuel pressure and it was only at 50 at idle heading to the track Saturday will post some times.
I saw you at the pits in Englishtown but never got to see your runs... how did it do?
jwfrauts
13.60 @106.89 7330 #s. 2.369 60'. It is making good power but no traction with the 305/40r22 tires. I guess it making too much power for the stock flexplate. It came apart on the way home from work a couple of nights ago. I am working 7/14s until the end of the month so I don't know how bad it is yet.
mgeistman
wow nice numbers!! thats a lot of power for 190's and pmax, good luck with the flexplate hope its not tore up too bad
windrunner408
VERY NICE. I know a lot of people will scoff at the Trap Speed because the HP calculator puts you over 600hp with 190s and a Powermax. Out of curiosity whose injectors are you running??
I would like to see what this thing would do with a MTW Stage 3 turbo in it.
imelmo
With a 4wd trapping 105mph was 12.5's. I would think with once you get the launch figured out in 2wd you should be able to get in some mid- high 12's with your trap speed.
mgeistman
What gear have you been using to launch? What psi are you leaving at?
jwfrauts
I am running Warren Diesel injectors with 75% tips. I have tried launching at 2,3,4, and 5 psi. The best 60' every was a 2.177 and that was before injectors. Most 60' times are in the 2.4 to 2.5 range. The 2.3 was with 30 psi in the rear air bags. I have only launched in 1st. Maybe I need somebody who knows how to drive. That was with ID extreme X. Also, the pmax has a batmowheel in it.
