Kind
- Joined
- May 18, 2011
- Messages
- 1,498
- Reaction score
- 1
Shawn's is about the same.
That's not bad. For some reason I was hearing otherwise. Video would be cool to compare against other setups.
How many passes did you make on that converter before it gave up?
it's already proven time and time again behind engines making far more torque than a V8 diesel... The design is based on a tried and true 70's design with a long history of drag racing builds.
There's so much R&D in making them hold up and they're so simple to control.
Not saying it's the best option for everybody, but if I was building an all out drag truck, I'd put a 47/48 in it no matter what diesel engine was in front of it
Have you guys ever ran Craig's setup with a factory stall? I still just can't help but believe the staging is putting tremendous stress on the converters. I mean, you guys made half the passes on an HD that Aaron has. Something to think about.
I wonder what the thrust bearing looks like in Craig's truck...
No matter what the trans will be needing a refresh @ 1,000hp IMO
let us know how that 5 disc ats works out for you, I have one in my truck and it work well but I dont use it like you do lolThe 5r110 really isnt that bad i have found how to get the clutchs to hold with out any of them burning up only thing i cant find is a good converter ive tried normal suncoast suncoast hd lasting the least now i currently have a ats 5 disc converter in it
Yes ats converter sucks soon as the turbo lights it blows through it
And it was brand new when I started with it
Anyone try RCD Converters? Seen in Diesel Power they have 6.0 and 6.4 converters.
