Radioflyer
- Joined
- Jan 8, 2012
- Messages
- 1,889
- Reaction score
- 0
I'll be hauling some ATV's over this weekend to the hills. Pulling some grades going as high as 5600ft above sea level. We will see how it drives.
I would think that you should have a pretty solid 625-640hp setup on stock fuel
Can't compare a loaded dyno to an unloaded. In fact you can't compare any dyno to each other. Loaded always seems read less. Did any other 6.4's dyno?
Yep, Curtis from vision dyno'd 566 and another 6.4 dyno'd the same.
Did they have stock chargers?
Guy over here did 650 with stock fuel on a dyno jet with a single last weekend.
But it's all numbers.
So...... track times yet?oke: lol
Sent from a Cummins plant, driving a Powerstroke, with a TDI on the side!
I'm thinkin my shift points need to be moved as well. I believe a 2200 stall converter would help a ton though.
