Right now it will turn 9 times. Is that right?
Sounds like the stop washer has gotten loose during the install. You are going to want to give tech support a call on Monday to fix that.
With the washer missing or broken, the far left will still be the lowest power setting. Anything past the 4th click (5th level) will be 600. It should stop on the 5th setting.
So no limit is the only place to get this ?
The first thing I will say is after running the 600qr tune for the last few months and around 4k miles. The sotf 600 tune is disappointing. All the tunes are good and smooth. Actually like the 400qr. Ill comment more when I get some more miles on it.
Anyone know if I can go back to the standard non sotf 600qr or do I have to disconnect the sotf knob first?
What's your other connection beside the switch there?? Almost looks like an air or hydraulic quick connect haha
I am running the sotf quick response tune. It feels like the first set of tunes that came out. Stock with more power. The 400-550 are nice and smooth. Power is there. I don't think the shifting is firm enough on the 600 tune. I didn't feel comfortable getting Into the throttle. I am just too use to the 600qr that was released sometime in March. Seems like the 600 had a lot more injector rattle too.
If I had to put a name on it I would call this tune set quick response non enhanced trans based on the other tunes. I didn't try the other two soft tunes. Sotf quick response enhanced trans would probably do it for me.
Btw. I am not bitching in the least bit. Don't take it that way. Just a current review. Everything is working properly which is great. No codes or anything. I'll probably go back to the 600qr till more tunes are released.
I wonder if the 15 and newer guys just need to wait on the new revision that will combine the enhanced shifting strategy at WOT with the regular shifting at part throttle?
To be fair, the 600QR tune *non-SOTF* is a work of art... The low throttle shifting and throttle response is perfect... makes me reaaaal curious on the new rev's...
