m j
stock pumps do spit the back cover out. so do t500s etc. if you use the search function you can find them.
as to why? I dunno maybe it has something to do with the added displacement maintaining more pressure.
links, first one is reman, second is T500.
http://www.powerstroke.org/forum/99-03-7-3-motor-problems/285449-hpop-blow-out.html
http://www.powerstroke.org/forum/94-98-7-3l-performance-parts/273145-hpop-blow-out.html
I have images from the forum of an adrenalin eating a spring but seeing as most of you cant/wont open a dead pump there is not too many images of the inside of an HPOP
why open it? simple, it takes maybe 20 minutes and only costs a gasket, an Oring and a seal on a running pump, to find out what actually happened and nothing to find out what actually broke.
your way takes weeks or months apparently and you never get to know what happened.
if 300 people provide data to the thousands of minds on the forum you are more likely to find the answer to what the issue is and discover if it is solvable.
if it is a different spring that needs to be used then lets replace the springs and move on.
please point out the downside to that idea.
right now we have no data
currently the forums have you, a guy who is incapable of wrenching, running his mouth.
so far that has achieved what? no efforts are being made to fix the issue.
now the only option is dual pump kits at least double the cost,
availability somewhat iffy depending on which way you want to throw your $2g+
or apparently unsolved stalling and idle issues with the gen3 style.
I am not BSing when I say I will buy some of the srp1.1 cores as I want the data and spare parts, if nothing else, to keep my truck on the road until a real solution arrives.
I have a 17° core I will swap right now if you would rather a core then cash.
