Steering box
DEEZUZ
NO PUKESTERS
NWI
Can anyone confirm if there are Teflon seals on the lines that go into box? If so what part number they are
DEEZUZ
NO PUKESTERS
NWI
Bang up job Usps
edge186
SLC, UT
I've been wanting to upgrade to a red head. I've been putting it off thinking it's going to be a pain to swap it. Does anyone know if there are any How To write ups on the topic? Or any insight on what to do or what not to do?
crowz
Administrator
Administrator
Its super easy to change the steering box out. Undo shaft from steering wheel at the box, undo power steering lines, remove pitman arm(a puller makes this super easy), remove bolts from frame hold box.
Reverse to install new box (make sure you do NOT turn the part shaft on the box much since its centered when it arrives) and top off fluids.
edge186
SLC, UT
Awesome, thanks. Now just to save up the money. I'm really looking forward to this upgrade. It has needed it for a couple years now.
DEEZUZ
NO PUKESTERS
NWI
Lol.. Yea... Still sitting On bench. Really don't feel like doing it
Jomax
Arizona
It's not too hard. I would change the lines while your in there. Mine developed a leak from rubbing the shock tower.
DEEZUZ
NO PUKESTERS
NWI
100% of my time at work is working on strokes, hence why I never touch mine. Got bout 5 Glow plugs out, brake sqeek, fuel leak, and pedestal pisses...
DEEZUZ
NO PUKESTERS
NWI
So I hit some tracks tonight and Holy**** instant death wobble. I've never experienced it before in this truck...
I'm Doing the steering box tomorrow, but is that the main contributor of teh wobble???
co04cobra
WV
Usually death wobble on leaf spring trucks is track bar worn out. You ever replaced the tie rods etc....?
DEEZUZ
NO PUKESTERS
NWI
Ball joints too. I'll look deeper, will I know if track bar is bad by wiggling it or what?
co04cobra
WV
Best way is to have the truck running on pavement, and have somebody else cut the wheel. Watch the bushings, if they're worn out you'll see the movement.
DEEZUZ
NO PUKESTERS
NWI
Hmm. Maybe I'll charge my go pro and watch em. I'll be posting in here tomorrow with what i find. Thanks
DEEZUZ
NO PUKESTERS
NWI
When I unlock the hubs and disengage 4wd. I get a grinding sound on left side after I hit bumps. The hub does indeed disengage I can spin driveshaft by hand. Any ideas
mustube
Austin, Tx
Spindle bearing inside the unit bearing. Its a little roller bearing for the axle shaft to ride on
Sent from my XT1058 using Tapatalk
