tell you in a few weeks.
my truck should be going back together week after next, with a set of crossbow's as part of it.
Installed them in my buddies truck about 9 months ago. Id give them a 6.5-7 out of 10. They were decent. I also installed 30% nozzles from swamps, downpipe, crossbows, with sh!tty spartan tuning.
Truck dynoed 604/1150 on the 310 tune.
Dynoed 3 months later, 601/1085 on the 250 tune.
Truck runs a 12.5 at 107, 1.68 60'. CONSISTANT ALL DAY!
2008 ECSB F-350, 20x10s with nitto 420s.
Truck now idles blue smoke. Believe the turbos are on thier way out. Turbos probably have around 120 passes on them, towed a 24ft enclosed with the race car in it for maybe 5000 miles. Total mileage on turbos, approximately 20k.
Switching to a single. Buying everything off a certain someones truck that everyone knows.
Was it dynoed at Swamps? I belive they have a Dyno Dynamics Dynometer so that is why I ask. All this means is that the numbers would be down about 15% compared to what people are use to seeing for numbers on a dyno because of its technology. The Dyno Dynamics is 15% lower than a dynojet.
Do you by chance know the correction factor of these dynos to a dynojet? Just curious.
The only dyno Swamps has is an engine dyno. I have had a set of turbos sitting in the garage for a couple months. Haven't had the chance to put them on. I'm a little scared to do it without studs so I'm waiting to get studs. I got a billet 71 and a 59 with a 64 wheel. I'm looking forward to getting them on the truck.
sent from the sea
sent from the sea
I'm curious about the above statement.
Did you ever monitor rail pressure? 30% nozzles with no HPFP upgrade is asking a lot with a tune commanding 2.3ms....I'm assuming the rail pressure was way low with the 310 tune and pretty good with the 250 tune.
Let me guess, the tuning was ****ty because the truck didnt maintain rail pressure without an upgraded pump.. thats definitely spartans fault
