T4 turbo kit
JDelaney
Medical Lake, Wa
Just pulled into Weiser, ID with my 39' toy hauler in tow. I'm seriously impressed with the 364.5! Tuning is not optimized (but we're working on that) but the truck pulls hard! I turned the chip down to the stock setting pulling Cabbage Hill (6mi 6% grade w/ 50mph switchbacks) and kept it floored almost the entire time. Had to slow down for the corners but once back on the gas the truck would accelerate. EGT were 1200, trans temp right at 185, ambient temps were in the low 90s. Got 8.5 mpg on the first tank of fuel.
cjfarm111
I like my 364.5 so. waaaaaay better then the HFSB. And Justin what makes the new version of the bell turbo better then the SXE 364.5? I know the cost isn't on its side?
Gainesville Ga.
I've never run a sxe, but it sounds like the 364 performs very similar to the BASB. But the sxe most are using the .91, where as the BASB uses the 1.10, usually spool would be sacrificed but was not the case at all with my basb, it spooled very quickly. I would have to imagine just based on the experiance s I've read on the sxe and had with basb, is drive pressure would be much lower with the bell turbo, and probably get as well, so probably also does better at higher power levels. Not really sure on this new new bell that is on dp's site either, sounds similar to the BASB. I know your experience with bell was terrible, but I absolutely loved mine, but I'm sure these new sex series are good comparison
06-6.0l, CCLB 4X4, studded, reworked heads, egr gone, cab reroute, blue spring mod, 6.4 banjos, updated dummy plugs, stand pipe, and stc fitting; New oil cooler, New ipr, New icp, atlas 40 FICM, powermax turbo, and Geerhead tunes, 325/65R18
Swaan
It all comes down to the size of the turbine wheel.
I don't know what the basb has for a turbine wheel but I'm willing to bet it is a 68mm wheel. This is why they are running a bigger 1.10 housing. The sxe 64.5 has a 73mm turbine and that's why people can get away with the .91 housing.
TMCCOY
Utah
Excellent to hear! I wish I had thought through the T4 a bit more before getting the 38R/upipes. It's not bad at all but, I have to believe the 354.5 is better! You were definitely stuffing the throttle to land at 8.5 too.
JDelaney
Medical Lake, Wa
With the 4.30s I'm turning 2200rpm @ 65mph. I found that if I sped up to 70 (2500rpm) and kept the turbo spooled up to 25psi I could pull most hills without downshifting. The RPM combined with a 12,000lb trailer are never a good combo for fuel economy, lol.
Justin@DP-Tuner
The 364.5 and FSSB are about the same, dimentionally. The main difference is the compressor wheel and the bearings. Pius' compressor wheel was designed by him. He pulls out the guts and upgrades all of them when building a turbo as well.
Justin@DP-Tuner
So the only difference is the compressor wheel design or is it a different size?
It is a 64mm compressor wheel, but different design. The standard BW housing (such as the one on your SXE) will not work on the Bell turbos because of this difference in design either.
Quit talking about these turbos! Im trying to be done for a while! I have 250/200s and 38r and want to run a 364.5sxe or 366sxe..
I do wanna and it's pissing me off lol.... this trucks been in pieces more often than not since 2013. Ive put 5k miles on it this year and now im thinking about ripping shti apart. LOL
Im liking the 364.5 for where my junk lives towing.
CarportMechanic
WA
I've been talking with Matt at Irate about a buddy's truck that is getting the works. He recommended a 369SXE for a 250/100 injector.
What are the intentions for the truck? I would think if hes going to use it for any kind of towing he would want the 66.
For a play truck or DD Id go the 69 route.
But we haven't really seen much feed back on the 369 yet.
