Stroked777
How many people have experimented with the 467fmw? Would that be another option over the 366? How much more power gain out the 67 over 66? And how would it be on stock fuel
Also has anyone ran a internally gated turbo on single setup? Or is it not possible or wouldn't work
Say it would fit and I wanna run spray, are internal gates just as good as an external gate?
how would a stage one cam effect a single turbo? i know the cam broadens the power band but how would running it with a single effect it? would it still be just as broad minus a turbo
You can come take a ride in mine if your up for the ride.
It will be even better. The extra drive pressure created by a larger cam will help spool and keeps the power band pulling hp higher. And since singles love rpm, a cam is a great addition.
I realize the stage (lift and duration) will be a factor, but would you expect a cam on a single (or even a compound) to raise the drive pressure mostly down low (when trying to spool the turbo) or would the effects be about the same in all RPMs up to redline?
Well cam timing is fixed through out the rpm range so yes it will create more drive at all RPMs. It's most needed/noticed at lower RPMs to aid in spooling. After that the higher exhaust pulse needs to be relived or higher BP will result.
The specs on the cam I got from RCD are .405 lift and 182/196 duration. I'm a been when it comes to what can specs mean,
Have a stage 2 in mine with valve reliefs
