transmission
jban126_f350
Phoenix, MD
These transmissions shift from 3-5. The direct clutch is for reverse and 5th.
How is reverse?
Reverse works fine. And like I said I only put 10 miles on it maybe with these new tunes. And that's when it started.
By the way have you guys ever heard like a ticking noise from the passenger side of the engine? Just a little tick tick tick over and over. When it's cold and warm. Idles fine. Anything wrong? Just paranoid?
swinky
Eastern, Nc
Sounds like a solenoid to me.
04cr450
harford county, maryland
No. Solenoid in the transmission(u have solenoids on the valve body). Sounds to me (from what my old Trans did) the line pressure control solenoid is acting up, this solenoid is tricky to change. Not as easy as changing the dd solenoid etc.
jban126_f350
Phoenix, MD
It's just so weird that I've never had any problem till I loaded those gearhead tunes. And like I said I've only driven it about 10 miles since I did the work and it's been acting up. Was thinking about upgrading transmission anyways. Was expecting this soon
jban126_f350
Phoenix, MD
I'm guessing the direct clutch solenoid doesn't give you any warming before it goes cause all I did was throw some injectors some new tunes and there it went. Didn't notice anything before that.
swinky
Eastern, Nc
depends. if its getting plugged up it will slowly get worse. If it has an electrical failure it can happen all of the sudden.
TequestaStroker
Same type thing happened to me recently and my clutches were toast n had to get my tranny rebuilt... Every situation is different though, so I wish you the best!
jban126_f350
Phoenix, MD
Thank you. I ordered a modified direct clutch and I'm hoping that will take care of it but if not truck may sit for awhile haha thinking the stage three twisted transmission when it comes time
jban126_f350
Phoenix, MD
Just curious how much fluid will I need to fill my trans back up after I install the direct clutch solenoid. Mercon sp correct?
