patrickke
Lance are there any signs of contact on the housing?
i already stated that the oil takes up the slack, but even still...it should not rub the housing even when the oil isn't there to take up the slack. I have yet to try and get one to do it. It'll come very close, but i still haven't gotten one to rub when pushing the shaft to the side and spinning it.
I would almost guarantee that it's a up pipe I've seen it to many times. Lol been working on 6.0 for a long time and thats what it sounds like to me
I had the exact same thing happen to my truck. Exact same thing.
It sounded just like the compressor wheel was contacting the housing, and I could push the compressor wheel up and dowm, which is normal.
It turned out to be the Metal gasket that was broken between the up-pipe and y pipe. It was rattling between the pipes, just like if you held a blade of grass between your fingers, snd blew. This rattle created a high pitched metal to metal sound similar to your video.
This guy had the SAME problem (according to him anyways) and it wasnt a bellows or flex but gasket between the y-pipe and passenger side up-pipe.
this is actually a great idea for me to check. I'll yank the pipes and give em look but there is absolutely no soot anywhere and as much noise as this thing was making, if it was the bellows, my entire firewall should be black. that gasket definitely makes sense....can i just get that piece from the ford house?
as far as the turbo goes...it shouldn't be touching the housing at all. whether it's making that noise or not isn't really an issue at this point.
