hell, just the tow power atmo got 645 (ish) on stock fuel..... add an air dog, lift pump, and 60 nozzles, and you should be there. But, that is the cheap route... not bad, mind you, but, all those parts are maxxed out at that level, and leaves no room for improvement later on...
the really expensive stuff, is all the things that you SHOULD do when climbing to that level. Trans, torque converter, studs, pushrods, valvetrain, plumbing, etc......
but, have fun with what you have, and drive it like you stole it!
It did like 655 on Rudy's dyno, but I think it's pretty understood that his dyno reads a little on the high side.
a little? hahaha
a little? hahaha
Poor Jeff. Cant get a break...Ever LOL
Well, my truck is a pretty good example of that dyno reading high.
i think the dyno reading 628 on a tune only truck said it all.
int: lmaoUgh, here we go. Ill get my boots.
Just something to think about. Not sure how much you really want/ is practical for you. But tonight, My truck was enough to scare the crap out of my girlfirend, kill a Duramax and just piss off a Cummins. And tomorrow I will be pulling a 17,000 lb trailer. I maybe just a little over a tune, But it feels like a lot more than just a little. stock fuel, stock trans. I swear my truck from a roll is as responsive as a gas motor. There is no lag before your sideways and pedaling the throttle. :ford:
U could do our tow-power x atmosphere turbo. Comes with evrything needed to install. It will support over 700. Add the zmax intake manifold to keep egts down and power up. If cost is not an issue do Tpx complete kit or high powers. Twin pumps or wait for our diy pump kit. 85hp nozzles. u would have a fun smoke free driver.
Is there enough difference between the tow atmo and tow x atmo to justify the cost difference
One is a modified stock low pressure with a 71mm billet wheel. The other is a 76mm Precision ball bearing. My guess is the potential power with added fuel is much greater with the 76mm. I would also assume that with it being a ball bearing it is going to be more reliable. I don't know the price difference though and I don't think there has been any dyno testing to see the true gains. You should be the first!
