Blowby
- Joined
- May 22, 2011
- Messages
- 1,532
- Reaction score
- 0
Just to comment on WOP's WG to atmosphere EGR delete I had Zane install. I can barley hear it when it opens. I see about 34 psi of boost with the HD225 tune at a safe speed. The cab insulation from the factory is so much quieter than my 00' which might be a factor. The sound outside might be a different story. I did spend time putting additional pressure on the top of the gate with the regulator until it hit 60 psi BP like I stated above. The WG was blowing open plenty of times until that point. I rolled under the truck and saw no sign of soot what so ever.
My thought is that once your boost is at the level to utilize the WG the combustion is being accomplished with a greater amount of air so the exhaust is clean, no smoke out the tail pipe. So when the gate opens you get the same result clean burning exhaust. Sounds logical and the lack of soot around the exhaust tube will be a strong indicator of my reasoning. I'll keep an update after some heavy towing.
