Well its been a fun ride!
Status
Not open for further replies.
yotaneck13
First round of what? Your not old enough to buy anything and I dont dig juice bar's...
If im old enough to recognize you in a picture on my girlfriends night stand. I think im old enough to drink.
sent while looking at my sled. since theres no freeeeking snow!!!!!
CSIPSD
Bend, OR
So does that mean your sleeping with my 62 year old mother???:puke:
You cant be older then about 15, because that's the only way I could see someone being as idiotic as you...
yotaneck13
Mabye it does!
yotaneck13
Ok so i finally got to look at the truck re installed the pcm. With out my chip. Charged the batteries. One is swelled pretty good. So new ones are in order. If i can figure this out.
I installed the new cluster. Plugged the modis in and nothing. It wont power on. So im guessing its fried? I hate to buy new batteries and a pcm to have that not.be the problem.
yotaneck13
Pcm is in. Chip is out. I sprayed eithet directly in the turbo just mow. And it rolls over unburnt either is smoking out my stacks but it will not fire. According to the guage cluster it is reading rpms but.my wait to start light is not comming on.
fordfreak4life
Check the fuse for ur power point on the dash, also the #22 underhood fuse iirc
Sent from my Milestone X2 using Tapatalk 2
ToMang07
Mainah!
my wait to start light is not coming on.
Going back to page one on this one:
PCM.
Check the fuses. If the fuse is bad, replace it. If the fuse is good and still no WTS.... THE FRIGGIN PCM IS DEAD.
yotaneck13
I thought it would register rpms if the pcm is fried. I sold some toyota crawler parts and my camper today so.tomorrow ill ne buying batteries from sears and ordering a pcm. If yall think itll run then
I was spraying and trying to start my self. It did seem to speed up the cranking with either but wouldnt start. Thats what has me worried.
fordornothing
Guernsey, WY
Aside from blatant maintenance requirements like engine oil, good luck breaking a stock 7.3 engine.
Seriously. Good luck with that. I know there have been QC issues with some stock engines, as with anything mechanical, but putting a chip on a stock 7.3 engine is just not tickling it's structural funny bone. At all....
Your only hope if you were to set out with the sole goal of breaking a stock motor would be to melt it down.
i had a chip on my old 96. that's it. drove it hard and it died. A LOT of metal in the oil... it can be done.
casper7.3
as said before check fuses.the fuse that turns on the wait to start light is also used to power the pcm relay. fuse no good, pcm no work. pcm no work, no talk with scanner.
yotaneck13
Ok i will check fuses tm
yotaneck13
Fuses are all good with the exception of the one for my tail lights under the hood. And that wont stay. As my harness is melted at the switch.
I believe someone owes someone else 20 bucks on a bet. As i actually got off my lazy as! And put some diag. Time in this weekend.
Charles
And you could have never ran the chip and probably still had the same issue. A bone stock truck can and will fail ever so often as it's made of parts produced by mortals.
But rest assured that the bearings, rods, pistons, block, heads, gaskets and all else gave not one damn about the whopping 215rwhp you were making... if that...
You pretty much turned your OBS up to stock superduty power, and had a bs problem.
Charles
To the OP...... what BRAND of ether are you using??? Get some JOHN DEERE ether and report back. If the engine does not...
A. Fire and run for 1 to 2 seconds
or..
B. Pitch a rod or two clean through the side of the block
Then you aren't spraying enough, or the engine in fact has NO compression.
yotaneck13
New batteries will b here today. I ordered a pcm should be here sometime this week. And i ordered pedastal rings. Also the rings for the fuel bowl valve.
Status
