Where did I go wrong?
I ran a CCT and it passed while in park, but in drive, it failed #6. That's the first time I've see it do that. I'm gonna climb in there tonight and make sure I didn't pinch or roll an O-ring.
what is your voltage while in drive with a lil load on the motor when you did the cct?
Tim @ P.I.S.
Sunny, FL
One would think that an injector can fire reliably at a stock ICP level unless there is something wrong with it.
So with saying that do you keep the same ICP at idle for A code, B code and hybrid injectors? Because I have never seen this the case with some tuners.
Gearhead
I run 500 on all of them unless I have issues getting them to fire at that ICP.
Tim @ P.I.S.
Sunny, FL
I agree that's all they should need. From us specifically our smaller injectors all move oil through the injector just as they did from the factory. And VOP is also to factory spec. So the only thing to consider is the nozzle size.
I have seen from time to time a poppet that doesn't move as smoothly and as quickly as it should. But we find that on the bench and that becomes a core trade in for our customers that request NEW injectors.
mandkole
Northwest
It always made sense to me that larger nozzles needed some extra ICP for the IP to stay crisp at idle, but perhaps that's not the case.
DocBar
Akron, Ohio
Cps are a crapshoot anymore :shrug: frustrating
That really pisses me off since mine only seem to go out when it's raining. I've had to swap out some that I just swapped in. In the rain, of course. Why is it so hard to make a reliable CPS?
Tim @ P.I.S.
Sunny, FL
That's way easy, how many did Ford have to give away and eat labor on for the last few years due to the recall?
Its a $$$$ thing. Order a few million from China for pennies on the dollar of the originals.
SDS97_7.3
Finksburg, Maryland
Cps are a crapshoot anymore :shrug: frustratung
I had great luck with my IH one. Original went out, then so did the recall one. Got one from International and never had a problem with it
DocBar
Akron, Ohio
Some people should've been fired for that call. That's called penny wise and pound foolish. :morons:
The Brad
People's Republic of CA
Here's an update.
I've learned that a cylinder contribution test doesn't work when the AIH is missing, it ends the test prematurely. So the next best thing is to cancel 1 injector at a time while watching MFD. Sure enough, when I canceled #7, there was no change in MFD. I reinstalled my AIH and ran a CCT and #7 failed. I emailed Tim @ PIS and he rushed me out another injector (I'm about 7 months past the warranty, thanks Tim). I moved #5 inj to 7 and put the new inj in cylinder #5 just to be sure there wasn't something else going on. I put about a hundred miles on it and so far, so good. The truck doesn't shake anymore and it's more responsive. I still have a fuel knock on the drivers side that sounds hollow, like someone's hitting the valve cover with a screwdriver handle, but it goes away on deceleration.There's also a loud tick and using a stethoscope, it sounds like the tick is coming from #2. I guess another session with a breakout box is in order.
Once I got some miles on it, I put in a Swamps HFHV IDM and it feels a tad smoother and I notice my inj pw got shorter by about 0.1-0.3ms at idle and cruising. I've only driven 10 miles with it so far.
I haven't towed yet to see how egt's are, but I don't see any difference while daily driving.
