Younger1993 build
Super08Duty
College Station, TX
We'll be fabbing all of the piping except for maybe a coldside pipe. Before pics of the piping are posted, let me warn everyone...I am no pro welder, but I will do whatever it takes to make sure the pipes are sealed and presentable when he pops the hood.
MorganY
college station, tx
Divided up pipes and .83 T4 will spool better then .70 T3 build looks awesome
Thank you. I will be sticking with the .70 A/R because I have ran one before, and liked the spool up. I can always change to a T4 later on with a few hours of work, I've got mockup motors and turbos to make a new set of up pipes if need be.
We're getting the pump mounted tonight, Colton's fab'ing a mount bracket as we speak. I Finished clearing out the manifold today
MorganY
college station, tx
This was after I used a 1/2" bit to clear alot of the bigger material out with the press. You need to use a larger 5/8" bit to completely remove the posts without having all these leftovers. I used a dremel with a cutoff wheel to remove the excess around the posts. Went back over them again with the press, set the height on the press so that each pass would be the same on each bolt hole. Then spent the next few hours with an angle die grinder and a grinding wheel to get the radius from the drill bit flattened out to the photo below. It's not the prettiest thing, but considering what this whole thing is going to cost me, well worth it.
Powerstroked162
On Da Juice
Wa. State
You don't have to use those if you don't want Morgan. The intake gasket has a rubber crush grommet that will seal the floor up.
Let me know if you need that coolant line kit brother!
