Pick the turbo set up, HPOP, fuel system and injectors of choice then get one of these. That will save time and money plus you'll have a great warranty by great people who know how to build a 7.3 the right way.
No need to get sore.
David builds a helluva motor. I am very happy with mine now that I finally have all the bugs worked out of it. None of those have been mechanical in nature.Doc, I see you have a David Lott engine, but recommended Swamps. Is there a reason for that?
I'm honestly asking because I've considered going the DI competition block route.
I'm not sore. I'm stating fact- I've even posted in threads with you in it about leaving that drama elsewhere - and I do mean that. Facts seem to be something that I have seen that you seem to want to argue with and contradict on multiple occasions with many people on this forum. As an additional piece of small and kind word of advice - look at your approach to others in your posting - perhaps that is why you seem to constantly be rubbing people the wrong way.
Personally i'd shoot myself in the foot before i'd try and build a 900hp work truck. I had large twins, and all the goodies on mine. I never dynoed, but it was definitely a big hp truck. **** broke.... all the time. It was bad enough i had to own another truck to drive while i worked on the other one and it took 2 years to work out the bugs. You might try 500 and see how it works for you before you shoot for the moon.
I'm talking about a Cummins conversion, not a new truck. If your'e a Cummins mechanic you should know your are making a mistake building a 7.3 IMO. Look at the fuel system, the common rail is light years ahead of the electo-hydraulic unit injector. I just does not make sense to me to put the time, effort, and money in to the 7.3 with your goals. If you want 350/700 fine, but more from an outdated design? You'll always have to turn it way down to tow too, it has 2 valves and a slobbering injection system. Really, do what you want, but I think it's a waste, not a challenge.
I'm for anything Common rail. It's just that the Cummins is easier. I think it would be awesome to put a Scorpion in to an older truck.
Im all for the.12v or 7.3td doing something. Id even entertain doing a cr retrofit to a 7.3 but I am about 20grand short of.what id need to.do it.
I think everyone needs to step back away from the keyboard. Everyone is new at some point - everyone has something to learn no matter how many years you've been doing it - or how experienced you might be.
This group "kill the inexperienced noob" mentality needs to stop. The guy is asking questions - just answer them to the best of your ability. Noobs also need to learn a little bit on how to state their wants, goals, desires, and what it means to be "currently working" on something.
To the guys that think this is such an evil hypocritical place where everyone puts others down and is flushed with cash - you are free to leave at any time - no one is twisting your arm to be here. You are here because this is the highest concentration of true PSD performance knowledge on the web. This place is built by the been there, done that Alpha males that have actually done or at least been part of many of the things that some people might consider "new and innovative" even though it was more than likely done without the internet flair months if not YEARS before the noobs ever made their first post.
I see problems on both sides - and the noobs and the vets need to learn to deal with each other.
To the OP: You don't need or want to run that heavy truck at 900HP on the bottle at the track - you'll never be happy with the amount of headache that you will have given yourself. 500-550hp on fuel with compounds on a stock bottom end will be awesome with the right combo of parts and tuning and you can enjoy it - even have a true 400-420rwhp tow tune if feel like upgrading everything in the drive line to be able to actually use it on a regular basis without melting your chit down.
Oh - and I might know a little bit about upgraded 7.3 internals.
Ah, well cheers to that buddy. Although I wouldn't say a 6.7 cummins would be any bit easier than a 6.4 or 6.7 powerstroke.
