funny guys
100% street legal with full coverage. why swp it? I have a stock tune and adjustable waste gate..Is the truck street legal at all? Do you have another truck you can swap the but 7.3 into and just de tune it
well, this happened tonight will out ***in around...![]()
believe it or not, it wasnt even from the corner that the coolant was coming from... blew the headgaskets but on the passenger side rear outside corner and the driver side front outside corner.. oil spewing all over... poped two of the freeze plugs out and on in the rear. unless it cracked the block and its dumping out as fast as it is poured in then its just a rear plug..
well since it pushed out both rear plugs on both sides of the block, started to push out a front plug and blew one of the plugs out on the rear of tye block(or broke a dig chunk of block out of it) id say it did compress... its spewing oil out each corner of the heads.At least you can find/found your problem easier.
Do you think compression entered the coolant gallery and pushed out the freeze plugs?
On a side note - from the Busch racing world, we drill a hole in the smooth area, beside the freeze plug for a 8/32 x 1/4 screw. Then put a small washer on the screw so it over hangs the freeze out plug.
Billy T.
[email protected]
yep.. no clue how they can be so identical too...Dam both heads huh
I noticed that, weird...yep.. no clue how they can be so identical too...
