question/tips/tricks/advice/how to thread
Powerstroke214
Baton Rouge, LA
Is there a way to turn the interior lights off while a door is open or before the door opens?
Sent from my iPhone 5s using Tapatalk
Don't the dome lights have an option saying something like "off door on"? An a switch or something? If not, there's a dial(I think it's a switch on the 6.7s) that let's you control the brightness of the interior lights, you could turn it down. I haven't looked recently, but I want to say we could mess w/ that through the dash center in the 150? I'd assume it'd be the same for the SDs.
Yes sir everything else is normal
Hmmm.. I would think that if your dpf was getting clogged, it would hinder boost.. but I dont know for sure.. I know with my truck that if I cant get much over 20 psi of boost, 22-23psi is the norm wot, a regen cycle is about to start...
Strokin&Smokin
Louisiana
There is an up and down switch for the domes but all it does is dim them way down. It's odd because every other truck I have had lets you dim them all the way down then the next setting is off. I'll have to go through the dash and see I guess.
BK39
Texas
For the tuned trucks, anyone else going crazy with the low rpm drone? My truck is annoying loud at low RPM fueling, 13-1600 rpm. Anyone try an aftermarket muffler?
I have 5" flo pro. I ran it with the flo pro muffler at first, then straight piped it, neither way works for me. Almost no difference.
MorganM
SE Houston
Anybody know of a good full delete kit with exhaust and everything?
Street Diesel Performance offers a delete pipe with integrated muffler- ordered mine with the ceramic coating option and I'm completely satisfied.
LINK
No muffler/ tail section change yet- but I don't have any drone and the truck remains 'stock-ishly' quiet.
Might try tye aftermarket section, maybe check websites for h&s, spartan, spe, innovative and a few others that I cant think of right now.
Duckdawg
Thanks, I just can't figure out what would cause the mileage drop, everything else seems to be fine no noticeable power loss or anything
Pirogue
Boost levels still the same cruising and wot?
I recommend putting a jack under the front diff and lifting it up. If not, some of the old oil stays in it cuz of the rear facing plug and the thickness of the threads on the valve. Unless you guys dont care about a little old oil leftover. As black as the oil is, id rather get it all out!
Just curious, is it ok to lift at differential? Manual says no.
