I know a little over the top with aluminum. First ones I found near me. There is another manufacturer I will look up. But they are either 18' 15000gvwr for $5600 but it is short. Bigger ones are hd equipment and like $10000 don't think so.
My bad Mike, I will stop the hijack.
Not too short?
For you 6.4 guys the difference between a "60", "100", "150", yada, yada, yada, injector is nozzle right?
It's just more flowable area, meaning that in the same duration, the larger ones will flow more fuel if you can keep the rails up...
Then you guys throw "200's" on a truck, make no appreciable change to reduce injection duration for that dramatic change to fuel rate, and you can't figure out why they aren't perfect little angels on the street???
And how with _____ turbos you can't use such a large nozzle because of inability to clean them up???
I guess each platform will have to let tuning inability rule them into using tiny ass nozzles time and time again before we can pull head from ass and cut the G'damn duration on a larger nozzle and make use of it like we have some sense.
God it's boring to watch this over and over. How long did it take us 7.3 guys? Then how long with the 6oh before people started running sane durations with fast injector nozzles? Now apparently we still feel the need to go through the motions all over again with the 6.4.
Nozzle limiting your drivability is a FOOLS GAME. It's ass backward. TUNE the injectors to provide the limited fuel quantity you want at low demand by reducing duration when needed. It's a CR injector folks.... it will roll over and let you rub it's belly if you just ask.
And if the multi-billion dollar mega code computers can't do that, then throw them away.
