Chvyrkr
- Joined
- May 18, 2011
- Messages
- 2,204
- Reaction score
- 0
Yeah, a little progress every night. LOL I finished stripping the front axle down and had Bryan burn on the new track bar bracket and coil over brackets on the axle, just waiting for a couple of tools to show up so I can set up the ring and pinion in the front (broke my dial indicator a while back, never replaced it, bought a Dana axle spreader). Last two brackets to weld onto the axle are for the hydro assist steering cylinder which hopefully is leaving PSC soon. I had to locate some fine thread 3/8 flanged nuts for the tcase which I have now, so I can install the 273 into the truck. I had to modify the skid plate for transmission pan clearances - I started plasma cutting out a chunk last night and cleaning it up with a grinder - just a little more clean up work to do to make myself happy with it - but before I finish I need to get it up under the truck and mounted so I can transfer drill the holes into the frame and make sure it all fits - then pull it back out and paint the skid.
I'm also going to need to build a new downpipe for the atmosphere charger because mine is going to have a major interference issue with the coil over shock tower - so I'm also looking at if I have enough room to upgrade to some aftermarket cast manifolds and up-pipes and still be able to install a down pipe that snakes around the coil over tower on the frame and the manifold.
Sounds about right for any major project...
Doh, downpipe don't fit now. Doh, need an adapter for brake lines. Etc...
