webb06 official build thread
bft blue oval boys
Burlington, NC
Well I'm sure you're monitoring everything and if everything looks good like your Rail Pressure and Low Pressure Fuel System my next move would be getting some 60% injectors from Morgan, Jarred, or MPD...
Sent from a Cummins plant, driving a Powerstroke, with a TDI on the side!
webb06
Seneca, MO
All PIDS are checking out except boost is low compared to a few other trucks. I just put in 150hp elite nozzles so I don't think going smaller will help. The pw is pulled back on these already
bft blue oval boys
Burlington, NC
Maybe try some 100% then. I think it was Dustin that switched out some Elite 150hp's with MPD 100% and picked up a considerable amount of power. I'm just throwing this out there though, it could be all boost related but I saw you said there are no boost leaks so I don't hardly know what to tell you lol. What intercooler is in it? I think it was Tony that had an aftermarket intercooler that had some kind of blockage in it and when he switched it out his boost went up. Again, I'm just throwing ideas out there.
Crack85
Midland, Tx
I don't think nozzles are his problem.....he has the stock intercooler swapped it out from his aftermarket one as it was causing an obstruction.
bft blue oval boys
Burlington, NC
Ahhh, so it was you that swapped the intercooler! Lol. Well ya got me man, I don't know what else it could be
B585Ford
WV
What was your boost and EBP at the track?
webb06
Seneca, MO
47 on boost and I blew the gate reference hose off the hot pipe so the gate wasn't opening on the best pass. The clamp wasn't tightened down. And I didn't run after that
B585Ford
WV
Do you know what the EBP was at 47 boost?
webb06
Seneca, MO
Are you leaning towards this being the turbos?
It very well could be. I know Aaron Rudolph is running the tow x setup on his grey truck and he said its a dog on the top end. He doesn't have any track times to compare with but I trust him since he knows his way around a fast 6.4
Athens, IL
If you can size one to where I can tow 10k lfbs up the mountains in Colorado. I'd for sure do it. We ride quads in the mountains and I have to be able to tow out there so that's the only thing stopping me really.
Well we could, but it wouldn't make any more power than what your making now. A big power single wouldn't work for towing at elevation.
