webb06 official build thread
webb06
Seneca, MO
Elites piping. Dark horse diesel up pipe. I'm assuming the up pipes are different from company to company otherwise it should have fit perfect with elite up pipes.
webb06
Seneca, MO
First impression...wow! I love this setup already. On the 250 spartan tune it'll roll the tires loose at 30mph. Wastegate needs a little adjusting but ebp's never got over 73-74
Mpoage
OKC, OK
We need videos!! :postwhore2:
bigrpowr
<How I Fly
Administrator
what kinda boost you seeing ?
one2nine
Altoona, Pa
A week from today lol. Mike should be sending my intake out Monday or Tuesday next week and mpd is getting my elbow I need. I'm more than ready lol. I'm working on getting a trans squared away so once the motor portion is done it'll get trailered to get the trans installed
webb06
Seneca, MO
Here's a few pictures of how I ran the fuel system lines and a list of fittings I used:
2- 12mm x 1.5 to -8an fitting
1- 12mm x 1.5 to -6an fitting
Both of those mount in to the pumps
Off the rear pump I used a -8an 90* fitting and 1/2 hose going to it from the fuel block.
3- -8an 90* push lock fitting
2- -8an straight push lock fitting
Off the left side of the block I used 2 -8an straight push lock fittings feeding the pumps.
To feed the block I ran the hose from the airdog to a -8an 90* fitting.
And out of the regulator I ran a -8an 90* fitting to go back to the tank. And a -6an 90* to come from the fuel cooler.
2- -6an banjo fittings
1- double banjo bolt
Off the lower pump I used
1- -8an 45* push lock fitting
1- -6an 45* push lock fitting
webb06
Seneca, MO
Also I lowered the cab down once and the down pipe was rubbing the firewall pretty badly...raised it back up and did a little bangin around on the down pipe to make a little room
And it's a good thing I raised the cab back up...needed to move the wastegate port down to the bottom rather than on top for a little more room and the plug that was on the bottom of the wastegate was only finger right. Glad I got to fix that!
one2nine
Altoona, Pa
Looks good. I'm thinking I might do a 45 off the second pump now looking at it. I bout 90* fittings but looks like the 45* will work better.
