Six_Sloww
The obvious, unwanted truth. In certain cases a little drag created by tires of larger size is welcome but in this case a smaller displacement motor crippled by even less air and a huge drag/resistance load waiting to be overcome by the boost you cant effectively make to begin with.
I bet that setup would rip with stock turbos or a 59/72. If you have to run a single get an s362 and see what spoolup is with a single.
Does anyone around here run an s362 as a single on a 6.4?
I've been wanting to try a single because I like the sound and simplicity, all I want is same or slightly more power than stock, clean and cool, and good spool up.
I know most people want big cheap power when they swap to singles, less upsides when switching to a single when big power isn't the goal.
