The 2011-16 Leveled Super Duty Thread
DarcyB
Airdrie, Alberta, Canada
The way i measure is I measure from the ground to the wheel well and subtract the distances to get my rake and to verify i measure from the top of the tire to the wheel well and verify that it is the difference. Thanks for the info.
Sent from my SGH-I337M using Tapatalk
Mesa, AZ
To measure you need two fixe spots. Typically one of the rim edges and the fender lip. You dont want to use the ground, as it can change, the rim will be in he same spot every time.
vilim12
I did it differently than most. Truck was nearly level so all i did was buy a 1.5 inch rear block from PMF to replace factory size block.
vilim12
What size wheel and tire setup do you have?
20x10 Fuel Maverick -24, Factory michelins 275/65r20. I came to love the tire size and will be getting the Dura grappler is same size. Fit is perfect and only had to tie back passenger fender liner carpet. Zero Rub
Black AOD
Ohio
I'm gunna have to get new wheels. Everybody has 20x10 fuel mavericks now. Dammit :fustrate:
NHRMK
I had to cut off the bottom part of the bumper brackets and it rubbed the back part of the wheel well but that was just cutting that felt stuff with a knife. ............. I guess that's also another question I have for anyone, how do you measure the rake of your truck? I have been told a few different ways but what is the best way to measure if your front and back is level or not?
Do you have any pictures for the full front and rear ? I'm looking at this exact set up just tying to decide between -12mm and -24mm. Thanks man looks great.
Stackedup6.7
Carli 2.5" coils American force Rebel 22x12 toyo open country 35x12.5
March244
Does anyone know if you can use stock 18" King Ranch wheels with the carli 2.0 backcountry level kit?
15 King Ranch 350
Front : 2 in ready lift level kit
Rear : 2.5 in helper spring
Shocks : stock rancho
Tires : stock toyo at2 275 65 20
Wheels : moto metal 907s I think 20x9
