700 hp goal build
powerjoke73
Progress on trying to polish the stack.
powerjoke73
Got some news on the truck today that it won't be done for awhile. Local machine shop is busy due to pulling and racing season.
I stuck the stack in my dads truck to see how it would look.
powerjoke73
Has anyone noticed a difference running a Melling LPOP? ( difference in start up and idle etc.) My LPOP is what let go in the first place and this was the only "upgrade" i heard about/found.
powerjoke73
Is that needed with 300/200s and a single HPOP? Or is the Melling at its limit? I do not plan on bumping up to 400/400 etc. Maybe some spray later.
Magnum PD
VA
Single HPOP, probably not needed. Just won't see full potential with using a single pump.
powerjoke73
Called them about it and I heard the words "lower failure rate" and that was all I needed to hear. Decided to do it as an insurance item. They said it has been run on stock injectors/HPOP.
The Brad
People's Republic of CA
Low icp? Whats that have to do with mileage? And the spray isnt lacking with a 200% nozzle. Im not sure what you were told but an 80% nozzle and a 200% nozzle are both virgin nozzles, the edges of the orifices over which the fuel passes are the same and atomization will be too.
What is PW on a 200% at while cruising at 35mph with high ICP? I would think at some point you need to pull ICP to meet MFD since the injectors can only fire so fast. The shortest PW I've seen on my 80% nozzles is 1.3ms before it drops to 0.6ms when the IVS switch kicks in. To get equal atomization between stock and 200% nozzles, won't you need the same nozzle pressure? I'm still trying to learn, so what am I missing?
Ive never looked. It probably depends on what gear its in. I hate when the trans shifts early and the ***kin truck is looking for an appropriate time to inject fuel. Which is what it sounds like you are referring to.
Ive never had issues with pw on an 80% nozzle being on/off, on/off. I can relate to it with 200% nozzles but n9y since I got injectors from pis.
And I wouldnt say you try to approximate the stock idle. As my swamps and pis injectors have both idled better. With and without tuning. My pis 250/200s idle nicer than ANY 7.3 ive heard before. Tim can get on nerves but his injectors have been phenomenal. And that's what matters.
http://s1142.photobucket.com/user/t... Uploads/20160717_181330_zpsteofk7pc.mp4.html
Dont mind the jabbering. I was trying to troubleshoot an intermittent idle issue. That was an icp sensor.
powerjoke73
I want to drop the "Off-Road" skid plate that is on the truck for weight reduction. Anybody know how much weight I could potentially save?
powerjoke73
Finally got around to making a prototype for the grille emblem. Should have the final aluminum version done later today.
