08Monster
- Joined
- Sep 8, 2013
- Messages
- 1,871
- Reaction score
- 0
Can I see some pictures of the MPD filter relocate?
Sent from my Moto Z (2) using Tapatalk
30% Dyno load wasn't enough for my 4.30 gears. It's silly clean on the streets.And even cleaned the smoke up a bit up on top!
Thats awesome man!!30% Dyno load wasn't enough for my 4.30 gears. It's silly clean on the streets.
Sorry to bother again but could I see that fuel filter relocate you mentioned early? MPD said nothing was available, and I need something like that to work with my dual fueler setup with the MPD piping kit. Doesn't all fit and work with the H and S fuel filter kit.Put down 874rwhp this weekend at the Morgan Primm fall brawl event. Had a wicked exhaust leak and boost leak. Turns out I had blow up pipe gaskets, blow up pipe Bellow and blown wastegate bellow. Took the cab off and had a fun couple days fixing everything.
Now what?![]()
More robust bottom end and top end, more air, more fuel, more trans
It made shy of 900rwhp and the injectors we're only at 1700us and 14* of timing along with ALL of the issues. I bet it would've been close with the 60s maxed out. I'd say it'll be well past 1000rwhp this go around.
You sell motor out of it Jon?
