- Joined
- Oct 3, 2012
- Messages
- 11,853
- Reaction score
- 39
do they actually make center caps that fit or still rockin the ghetto axle caps...
Lmfao!These fit the rear caps you picky canuck
Oh sh!t man!!!! Wtf... that sucks!! Hopefully plans for the better!Most of you are going to find this surprising most likely but the truck will be getting posted up to be sold here soon. Plans are changing for me.
If anyone is interested beforehand, DM me or text me if you have my #.
Sale post coming for it soon.
I did find time dyno the truck finally at Firepunk Diesel. It made 757HP/1295tq on a 1450us tune and it was dropping rail pretty good at the top end. So either something on the low pressure side isn't getting the exergy cp4 what it needs or the Exergy CP4 just isn't performing as it should, the setup should have done well north of 800, more like 850 if not more so...now to figure out the issue there. The prior run made 721 HP on a 1110US tune and that file couldn't even maintain full RP throughout the run either. Personally I suspect my exergy 10mm pump isn't strong enough to make the power but I'm not sure honestly.
Torque # is low because we started the runs at 2500RPMS and ran them till 3700-3800 to keep the stock motor happy.
No. FASS 140. Fass fuel bowl ******. Beans Diesel Sump.Do you still have your stock lpfp?
Sent from my SM-G988U using Tapatalk
It doesn't matter stock or aftermarket as long as its getting the minimum amount of LP fuel needed which is at least 80-85 psi I believe but OEM calls for 110psi and that's what my FASS is showing as delivering so idkYou think it’d be happier with the stock? I think exergy says the stock is good for it.
I dig it!New AF wheels got put on for spring/summer. I'm liking the new nitto 420V tire so far
Yeah. Lol....those jerks.Nice little suprise seeing a Ford on firepunks YouTube page
