The easy way to stud a 7.3
TARM
I would call that easier. Truly easy is having someone else do it for ya. :D
Dieselboy.
Surrey B.C.
Its even easier when you don't have the frame and wheels to work around :)
Engine stands are a wonderful thing !
4.0l sahara
shelton,ct
Im putting my studs,springs,push rods,gen3,injectors in and building my tranny. I've had all the parts just no time to do it.
TARM
The issue is taking off a cab is only an easy option for those that have access to a lift. That eliminates about 90% of those that work on their trucks. Regardless for me pulling the cab is a MUCH larger job when its an Excursion. I do want to pull it one day though to clean up the frame and undercarriage and get a good coat sprayed on it.
4.0l sahara
shelton,ct
not hard at all just like a 6.0 with a couple little things that are different. The first time doing it it shouldn't take more than 2 hours. Once you get it down it's very easy.
