White smoke on startup
Rmartin-97
Mcarthur ohio
I noticed my truck white smoked twice now when I start it the only codes or anything I've noticed is check air filter light could that cause the white smoke? Or should I run a contribution test on my injectors or something like that?
3brorce
Yup most likely is it with the moisture. I put my no limit and cac pipe on last week and there was moisture in the cac pipe. I got white smoke on startup as well when cold
WoodBoy
Alabama
Are you talking it only does it first thing in the morning after a cold night? Or like when you drive to work and you get off work for lunch it will do it again after the motor has sat and cooled down but not cold?
Rmartin-97
Mcarthur ohio
Only when you drive it let it cool down for a few them restart it. It does nothing when you start it in thee morning.
3brorce
Could be some moisture(water) in the bottom of the intercooler maybe? Common for 6.4s to get water built up in intercooler
Heavyhaul
Wyoming
Both there is nothing left but the moisture in the cooler that I originally said.
Rivets are the new duct tape.
BigBluediesel08
Laredo,Tx
Mine also started doing it after getting studded..it only does it when it sits all night or a couple of hours. Doesn't smell like raw fuel.
