OBS 7.3 engine and pickup build HP goal is in the 600HP range
bluedge8
Champlin MN
you need a repair manual, that will at least give you torque specs and tightening sequences, which is the main reason I buy haynes manuals
Powerstroke Cowboy
Montana
I ran in to a slight problem.... I do not know how to adjust the camshaft timing. SO that puts a stop to my project till I get that info...
Powerstroke Cowboy
Montana
LOL I feel stupid... The marks are right there to go by!!! So it done.. I am just kicking my self though.. I went through all the work of pulling the cam... And did not have one of Matts to replace it with!! O well the new engine will get one..
Powerstroke Cowboy
Montana
I got the engine set back in today. I had to move a little bit of snow with the tractor before I could get to the pickup to drop the engine in it. Now I just need a good day So i can put the front end back together, and wait for a transmission spacer to get here so i can put the transmission back in. I should have it all together if we have no calving trouble tomorrow. Well all of it but the transmission.
Powerstroke Cowboy
Montana
It lives!!!!! Cranked for a total of about 6 to 7 seconds and it fired right up!!! Sounds good without that knock!! Now time for some tuning!
Powerstroke Cowboy
Montana
If it not one thing it another. Funny thing is it ran for about 6 minutes no problem. I shut it off started it back up ran good did this a couple of times no problem. Let it sit for about 30 minutes and started it back up ran for about 5 to 6 seconds and it shut off, and would not restart. Checked the HPOP reservoir and it was dry! Filled it up and it started right back up ran for about 6 seconds again. after trying this a couple more times I quit and pulled the LPOP and changed it out with another one I had laying around and still no go. same old thing. starts and runs for 6 seconds then it dies. I might have to change the front cover. it has a little bit of scoring on a 1/4 of the surface.
I will try a couple more things on Monday, to see if that is it. I hope the oil pickup did not crack!! Might jack the back off the ground and see what happens.
JD3020
Farmersville/Dayton, Oh
And thats why i welded my pick-up. Only way its gonna crack is if a rod goes down through the crank and takes it out. LOL
Powerstroke Cowboy
Montana
I hear you there! I think it is the LPOP. I put a used one in but still the same thing. I am going to put a melling in there and see what that does. Right now i have no desire to pull the engine back out! The front cover has very light scoring marks for about a 1/4 of the way around the crank. not sure yet if that is what is keeping it from pumping. So I am picking up a melling pump. And if that does not cut it. I am going to jack the pickup up to "flood" the oil pup with oil and see if it works than. To bad the front cover cant be changed with the engine in the pickup!!!
Old OutLaw
Suthren OryGun
can't remember where it was, but I was reading a similar deal the other day.....guy forgot to put one of the plugs in the back of the engine....oil was going down the rail, and right out the back, back into the pan...wouldn't run. hope that ain't whats going on here.....
Powerstroke Cowboy
Montana
No that would not be what is wrong here. I never pulled a plug on the rail.
All i need is a new front cover and oil pump. then I am good to go. Bought the oil pump but still looking for a front cover.
Powerstroke Cowboy
Montana
Exhaust housing ceramic coated inside and out.
Now That the engine is coming back out I might do the up pipes to. Would be nice to have it done.
dentexpowerstroke
denton, tx
Anti drain back? I know one guy had this issue and i guess a valve was stuck open draining all the oil before it could refill itself. ill text him in the am and see exactly what it was.
